HP Photosmart Premium C309g Scanner Glass Replacement
  1. HP Photosmart Premium C309g Scanner Glass  Replacement, Scanner Glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the scanner glass piece from the printer.
  7. HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Photosmart Premium C309g Scanner Glass  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The scanner glass is attached to the plastic piece with adhesive tape.
    • Pull off the glass and re-set new piece of glass.
Laura
crwdns2935283:010/23/14crwdne2935283:0
706 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-2, Lauer Fall 2014 crwdns2935289:0Michigan Tech, Team 1-2, Lauer Fall 2014crwdne2935289:0
MTU-LAUER-F14S1G2
Hi there,
I see these instructions was published some time ago and I hope someone still knows something about this printer. I have a question about step 2 and 3. It says you are to pry trim pieces and remove side panels. What is the difference between these two? When I lift the scanner module (or whatever it's called) I see only one type of panels. And wouldn't step 2 be easier if the scanner module is lifted first as in step 3? I don't understand why it's done as shown, but maybe there is a certain reason.
The front and the side panels have hooks that are attached to the underside of the module, so there seem to be no way to pull the panels outwards. Looks more like they should be pulled downwards, but seeing how the plastic frame around the scanner glass looks in the picture at step 6 I assume that's not possible. Could someone please explain step 2 and 3 for me?
/Jack
Jack - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 874
