To remove the hard drive you will need a Phillips PH1 screw driver. Caution not all screws will completely detach.
Shut down the computer.
Turn computer upside down so the base is facing upward.
Slide latch next to battery icon until battery pops up.
Pull the battery away from the computer until completely detached.
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
Slide cover toward empty battery area and remove it.
Disconnect the hard drive cable that is plugged in.
Lift the tab on the hard drive to pull it out of the computer.
Hard Drive is removed.
