HP Pavillion dm1-3010nr Hard Drive Replacement
  1. HP Pavillion dm1-3010nr Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the battery removed, the back cover can be taken off with your hand.
  4. HP Pavillion dm1-3010nr Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips 0 screwdriver to remove the four 2.5mm Phillips screws which hold the hard drive in place. You can see the 4 screws in the picture circled in red.
  5. HP Pavillion dm1-3010nr Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To disconnect the hard drive from the motherboard, pull the black tab as seen in the picture.
    This step #5 is completely wrong! You have to detach the SATA-connector from the HDD/SSD, NOT from the Mainboard! If you first execeute step #6 you can disconnect the SATA-connector from the HDD/SSD much easier because the metal cage will not block the connector anymore.
    Peter C. - crwdns2934203:0crwdne2934203:0
  6. HP Pavillion dm1-3010nr Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavillion dm1-3010nr Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the enclosure from the device, use your Phillips 0 screwdriver to remove four 3mm Phillips screws. There are two screws on each side of the hard drive enclosure.
Amitpal Gill
crwdns2935283:010/22/18crwdne2935283:0
375 crwdns2915208:0crwdne2915208:0
UC Davis, Team S7-G1, Lore Fall 2018 crwdns2935289:0UC Davis, Team S7-G1, Lore Fall 2018crwdne2935289:0
UCD-LORE-F18S7G1
Schritt 5 ist leider komplett falsch. Der SATA-Stecker muss von der Festplatte/SSD gezogen werden. Nicht irgendein Kabel vom Motherboard. Den Stecker zieht man einfacher von der HDD/SSD weg, wenn man zuerst Schritt #6 ausführt, dann ist die Metall-Lasche am Kopf des Steckers nicht mehr im Weg.
crwdns2942667:0crwdne2942667:0 1,406
