This guide will explain how to replace the screen, assuming none of the electric connections have been damaged and the screen is the only damaged part. Some of the inner parts have sharp, metal corner and minor injury can occur if you rush through the guide.
Remove two 5.0 mm Philips #0 screws on the hinge of the device
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
Remove the connection between the plastic case and interior of the device
Remove the connection from the exposed hinge and interior of the device
Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
Unscrew the six 5.0 mm Philips #0 screws underneath the caps
Using a spudger, pry the plastic casing off of the screen.
Remove four 5.0 mm Philips #0 screws located in the corners of the screen
Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
