HP Pavilion x360 m3-u103dx Battery Replacement
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
    Missing step: remove the screws on the bottom. This photo just shows the screws already removed.
    Aidan Gibson - crwdns2934203:0crwdne2934203:0
  2. HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
    How do you disconnect the three cables?
    andrea alley - crwdns2934203:0crwdne2934203:0
  6. HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 m3-u103dx Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
    There are 4 additional screws that should be removed that can be found under rubber coverings underneath, on the front side of the laptop
    CP COMPUTER TECH - crwdns2934203:0crwdne2934203:0
    There are 4 additional screws that should be removed that can be found under rubber coverings underneath, on the front side of the laptop.
    Dp you have the part number for the battery?
    T FHL - crwdns2934203:0crwdne2934203:0
Meaghan Hyatt
crwdns2935283:001/17/19crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G6, Munoz Winter 2019 crwdns2935289:0Eastern Washington University, Team S2-G6, Munoz Winter 2019crwdne2935289:0
EWU-MUNOZ-W19S2G6
Can i use the laptop even without a battery??
PAPISSS PH - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 7,180
