If the hard drive is malfunctioning or needs to be upgraded, use this guide to replace it.
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
Remove all of the screws located on the bottom of the laptop:
5 Phillips 2.4 x 5.7 mm screws
5 Phillips 2.0 x 5.0 mm screws
“5 Phillips 2.4 x 5.7 mm screws”
“5 Phillips 2.0 x 5.0 mm screws”
I think the color for the sizes are mixed up, because the one near the screen bending part are the bigger ones, yet it says they are the “2.0 x 5.0 mm” but they are the bigger ones.
If I’m wrong, tell me because I’m not sure if thats the ways they’re named because I’m not an expert at screw sizes.
Turn the computer over onto its base, with the computer open and the keyboard facing upward.
Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
Raise the keyboard slightly to access the touch pad and keyboard cables.
crwdns2935267:0crwdne2935267:0Heavy-Duty Spudger$4.99
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Lift the keyboard away from the base of the laptop.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
Using the tab provided, lift and remove the hard drive out of the laptop base.
Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
Follow these instructions in reverse order to reassemble your device.
crwdns2935229:09crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Awesome. Thanks. This helped me a lot.
Can anyone tell me the model number of the hdd ribbon cable please :)
I need to replace the data ribbon as well.
KurwynK -
Found it. part# 856011–001
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get 3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
I have the same issue, please let me know if you fix it.
Very helpful, thank you! My model (m1-u001dx) had an extra screw under the long rubber strip in the middle in case that helps someone else.
I have a x360 m3 from 2018 that looks identical to this one on the outside, but when I opened it up it had empty space where the SATA drive would have been. So be warned to disassemble before you buy your replacement part. In this case, the attachment point on the motherboard for the ribbon cable was bare, so even if I could have found the HD "caddy" there wouldn't have been a place to plug it in. My only option was to buy a new m.2 board.
