If your laptop is unusually loud or warm, the fan may need to be replaced. To replace the fan, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Power off your device and disconnect all external devices connected to the laptop.
Flip the laptop over and remove the rubber foot with a Metal Spudger.
Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
5 Phillips 2.4 x 5.7 mm screws
7 Phillips 2.0 x 5.0 mm screws
Flip the laptop back over and open it; the keyboard should be facing upwards.
Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
crwdns2935267:0crwdne2935267:0Heavy-Duty Spudger$4.99
Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
3 Phillips 2.0 x 4.6 mm screws
Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
8 Phillips 2.0 x 4.7 mm screws.
Disconnect the 3 bundle cable connectors by gently gripping the cable wires and pulling outwards.
Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Gently lift up the motherboard to disconnect it from the computer.
Disconnect the bundle cable connector by gently gripping the cable wires and pulling outwards.
Peel off the black sticker to expose the screws underneath.
Remove the 4 screws from the motherboard with a Phillips 00 Screwdriver.
4 Phillips 2.5 x 5.5 mm screws
Disconnect the fan from the motherboard by taking out the screws.
Hello,
Where can I get the replacement fan? Or which model is it?
THANKS!!
Katie, 10 stars on this. It 100% accurately describes the replacement of the whole keyboard deck including the kbd and the touchpad as one unit. Please put in a warning, the keyboards being sold that are only the keyboard poriton are not valid replacements. I have tried to do such a replacement of a $30 one and there is no way to separate the deck from the keyboard without damage. Again, kudos on this, i opened the computer with zero problems and then hit the wall. I will be buying a replacement deck with the kbd and pad - once assembled, diassembly and replacement is just not the way.
Ralph Brandt - crwdns2934203:0crwdne2934203:0
