HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement
  1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch and lift the small WLAN plate.
  5. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use PH1 to remove the 2.5mm holding screw.
  6. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the SSD out and up, away from the connector.
Amber Norton
crwdns2935283:009/14/22crwdne2935283:0
661 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-3, Virtue Fall 2022 crwdns2935289:0Western Carolina University, Team 1-3, Virtue Fall 2022crwdne2935289:0
WCU-VIRTUE-F22S1G3
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 673
