Use this guide to aid in the removal and replacement of the fan and heat sink to any HP Pavilion x360 14m-cd0005dx laptop. Replace the fan if the computer cannot stay cool during use. For further information as to whether the fan and heat sink should be replaced, look at this troubleshooting guide.
The fan and heat sink are essential parts of any laptop. After replacing the fan, an increase in computer performance can occur as components that were formerly overheating are now able to run at full capacity. If the fan and heat sink needs to be replaced but are not, further damage to the system can quickly happen. Device components may break down and melt if they are not cooled properly. It is far easier for a laptop to overheat when the fan and heat sink aren't functioning correctly.
Turn off and shut down the computer.
Disconnect the power adapter and all external devices connected to the computer.
Flip the device with the backplate up and with the hinge on the far side.
Use the opening tool to remove the rubber feet attached to the bottom of the device.
Remove all screws located on the bottom of the device:
Two Phillips #0 7.0mm screws
Three Phillips #00 4.5mm screws
Using the opening tool, carefully remove the bottom cover from the device.
Use a #00 Phillips screwdriver to remove:
Six 2.5 mm screws
Carefully lift from the base and remove the battery.
Remove the tape that secures the fan to the computer.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Find the fan cable
Use the Reverse Tweezers to unplug the fan cable
Remove all screws securing the fan to the device:
Two Phillips #00 4.5mm screws
Four Phillips #00 4.5mm screws
Lift and remove the fan and heat sink from the device.
