HP Pavilion x360 14m-ba114dx Speaker Replacement
  1. HP Pavilion x360 14m-ba114dx Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a #0 Phillips-head screwdriver, remove the three 5 mm screws along the bottom of the back cover.
    • Using a #0 Phillips-head screwdriver, remove the 6 mm screw at the top of the back cover.
  2. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the flat end of the Spudger, pry up the two rubber feet on the top of the laptop's back cover.
    • Using a #0 Phillips-head screwdriver, remove the 8 mm screw under each of the rubber feet.
  3. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop, with the display fully extended to 360 degrees so that the screen is on the table.
    • In this orientation, sliding the laptop around may scratch the screen. A blanket or a mat placed under the screen will help to prevent scratching.
    • Using the thinner end of an iFixit Plastic Opening Tool, pry open the keyboard panel from the base of the laptop near the screen hinges.
  4. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit Plastic Opening Tool and the iFixit Opening Picks, work your way around the rest of the keyboard and pry it out of the base.
  5. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the keyboard with both hands and gently lift it out of the base.
    • Do not lift the keyboard completely out of the base, as there are ZIF connectors that must be removed first.
  6. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic Spudger, remove the ZIF connectors that attach the motherboard to the touchpad and the keyboard. Use the flat end of the Spudger to pop up the cap on top of the connector. The connector will then slide out of place.
    • Repeat this step for all three connectors.
  7. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat end of the plastic Spudger, remove the ZIF connector attaching the volume button and headphone jack to the motherboard.
    • This ZIF ribbon is glued to the middle of the battery. You do not need to separate this ribbon from the battery in order to remove the battery from the device. You only need to unclip it at both ends.
  8. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #1 Phillips-head screwdriver, remove the seven 4 mm screws around the battery.
    • Gently move the ZIF connector out of the way to reach the screw marked in orange. Then use the #1 Phillips-head screwdriver to unscrew it.
  9. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the thin end of the iFixit Plastic Opening Tool, pry the battery out of its place inside the laptop's base.
    • Next, use your fingers to pull the battery out of its position.
  10. HP Pavilion x360 14m-ba114dx Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement, Speaker: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Halberd Spudger
    $2.99
    • Using the curved end of the Halberd Spudger, disconnect the Speaker Cable from the port that connects it to the motherboard. To complete this step, use the curved end of the spudger to pry the plug out of the port.
  11. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic Spudger, remove the touch screen ZIF connector by popping the cap up on top of the connector and sliding it out of its slot.
    • Move the wire away from the connection point to disconnect the touch screen cable from the motherboard.
    • Pull the wire out from its track next to the speaker.
  12. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Blunt Tweezers to disconnect the Wireless Card Antenna Cables. Start with the cable labeled M2, which is connected to Port #2. To disconnect he cable, grab it on both sides with the tweezers and pull up.
  13. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Blunt Tweezers to disconnect the Antenna Cable labeled A1, which is connected to Port #1. To disconnect he cable, grab it on both sides with the tweezers and pull up.
    • Using the Blunt Tweezers, unwind the cables from the track to the right of the speaker. The cables are held in place by two black hooks.
  14. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the #1 Phillips-head screwdriver, remove the three 5 mm screws that connect the speakers to the laptop base.
    • These screws only have 2mm long threads, but have 5mm in total length after the screw head.
  15. HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 14m-ba114dx Speaker Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the thin end of the iFixit Plastic Opening Tool, pry the speakers out of their place inside the laptop's base.
Caleb Murray
crwdns2935283:001/24/20crwdne2935283:0
969 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G4, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G4, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S6G4
crwdns2942667:0crwdne2942667:0 1,430
