HP Pavilion x360 11-p110nr Touchpad Replacement
  1. HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Once the screws are removed, carefully take the bottom plate off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the five 6.7 mm screws that secure the battery.
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the hard drive.
    • Locate the cable for the battery and the cable for the speakers and unplug those as well.
  4. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all screws are removed, carefully remove the battery and hard drive as one unit.
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  5. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the battery and hard drive are removed, you should be able to see the touchpad.
  6. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the cable for the touchpad and unplug it.
    • Remove and install carefully as to not damage the cable.
  7. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 3.2 mm screws that secure the touchpad bracket.
    • Slowly lift up the bracket and remove it.
  8. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 2.35 mm screws that secure the touchpad.
    • Remove the cover holding the touchpad in place.
  9. HP Pavilion x360 11-p110nr Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now remove and replace the trackpad.
    • Be careful not to scratch the screen during the replacement of the trackpad as the screen will be located directly underneath the trackpad.
Aeorrell
crwdns2935283:003/27/23crwdne2935283:0
433 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Spring 2023 crwdns2935289:0IUPUI, Team 1-2, Harley Spring 2023crwdne2935289:0
IUPUI-HARLEY-S23S1G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 105
