HP Pavilion x2 10-n113dx Hinge Replacement
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx Hinge Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
Ajay Panuganti
crwdns2935283:004/01/19crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G4, Harley Spring 2019 crwdns2935289:0IUPUI, Team S1-G4, Harley Spring 2019crwdne2935289:0
IUPUI-HARLEY-S19S1G4
crwdns2942667:0crwdne2942667:0 1,364
