HP Pavilion x2 10-n113dx Mainboard Replacement
  1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
    How do you replace those magnets that help snap the laptop's into place?
    Alfa Orellana - crwdns2934203:0crwdne2934203:0
  6. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  7. HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion x2 10-n113dx  Mainboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove mainboard.
David Zambrano
crwdns2935283:009/28/17crwdne2935283:0
837 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G4, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S13-G4, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S13G4
crwdns2947412:05crwdne2947412:0
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - crwdns2934203:0crwdne2934203:0
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - crwdns2934203:0crwdne2934203:0
It is not SSD drive, it is a motherboard
Da K - crwdns2934203:0crwdne2934203:0
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - crwdns2934203:0crwdne2934203:0
Do you happen to know how to reset the BIOS on this board if it does not boot?
Lewis Fields - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,868
