There are a few reasons you may want to replace your display assembly. The display assembly is broken, the display assembly is punctured, most of the display assembly components are damaged, or you would rather replace the display assembly fully instead of a single component. Whatever the reason, this guide will show you how to replace the display assembly.
            Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
            Use your thumb to pry up the edge of the battery and lift it out of the device.
            Using a Phillips #0 screwdriver, loosen the service door screw.
            Lift the service door up and away from the device.
            Locate the hard drive cable connector pull tab.
            Pinch the pull tab pulling upwards from the motherboard to disconnect the hard drive cable.
            Use a spudger or other ESD-safe prying tool to lift one side of the hard drive up and out of the base enclosure.
            Grab the end of the hard drive.
            Pull the hard drive out of the base enclosure at an angle.
            Using a Phillips #0 screwdriver, remove the optical drive anchor screw.
            Insert the flat end of a spudger into the optical drive release access hole.
            Orient the device so that you can remove the optical drive.
            Using a spudger, slide out the optical drive enough so that you can grab it with your hand.
            Remove the optical drive by pulling it out of the device.
            Locate the screw that secures the keyboard.
            Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
            Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
            Turn the device over and open the laptop.
            Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
            Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
            Locate the keyboard cable connector.
            Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
            Pull the keyboard ribbon cable out from the connector.
            Remove the keyboard from the device.
            Locate the power button cable near the top left corner of the upper case assembly.
            Using a spudger, flip up the power button ribbon cable locking tab.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using tweezers, pull the power ribbon cable free from the connector.
            Using tweezers or a plastic opening tool, disconnect the speaker cable from the black connector located near the right side of the laptop.
            Locate the track pad cable near the track pad.
            Using tweezers, pull the trackpad ribbon cable out from the connector on the motherboard.
            Locate the three Phillips M2.5 x 6.5 on the upper case assembly.
            Remove the three Phillips M2.5 x 6.5 screws from the upper case assembly using a Phillips #0 screwdriver.
            Remove the upper case assembly by lifting it away from the rest of the laptop.
            Locate the display panel cable.
            Disconnect the display panel cable.
            Using a Phillips #0 screwdriver, remove all six screws securing the display assembly hinges to the laptop.
            Lift up and remove the display assembly from the laptop.
