This guide will show you how to replace the HP Pavilion g7-1368 hard drive. This process should take approximately 10 minutes using only a Phillips #1 screwdriver. Make sure to shut down the device before proceeding with the replacement.
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
Lift and remove the battery from its compartment.
Loosen the two Phillips #1 screws that connect the service panel to the device.
Slide the service panel down and pull it up to remove.
Locate the hard drive.
Disconnect the cable connector by pulling it away from the hard drive.
Remove the hard drive from the device.
