HP Pavilion g7-1365dx RTC Battery Replacement
  1. HP Pavilion g7-1365dx RTC Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RTC Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion g7-1365dx RTC Battery Replacement, Service Door: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion g7-1365dx RTC Battery Replacement, RTC Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the RTC battery power cable from the system board.
    • Remove the RTC battery from the system board. (The RTC battery is attached to the system board with double-sided tape.)
    • Slide the RTC battery out from under the surface of the base enclosure.
Derrick Manu
crwdns2935283:003/18/19crwdne2935283:0
245 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G1, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G1, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S1G1
crwdns2942667:0crwdne2942667:0 1,904
