This guide will give step by step instructions on how to remove and replace a battery in an HP Pavilion g7-1365dx. Use this guide if you're having issues with a battery that is either not charging, or not holding a charge for long. This guide can also be used as a prerequisite guide for more involved replacements.
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
