HP Pavilion g6 Base Replacement
    • Simply slide the lever to the opposite position, and then the battery will rise upward. Grab it and pull it out.
  1. HP Pavilion g6 Base Replacement, Remove palmrest screws & bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five M2.5xL6.5 palmrest screws...
    • ...as well as the captive bottom cover screw. Slide the bottom cover away from you and pull it up.
  2. HP Pavilion g6 Base Replacement, Remove more screws & hard drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four M2.5xL6.5 screws securing the keyboard, disc drive, and palmrest.
    • Pull upwards on the hard drive connector, and remove the hard drive.
    • Remove the two M2.5xL4 screws revealed by removing the hard drive.
    • Remove the single small screw holding the wireless card, and undo the antenna connections.
    • Use your fingernails to get between the palmrest and the keyboard, and pry the keyboard out.
    • Unlock the connector underneath the keyboard, and remove the cable from the connector.
  3. HP Pavilion g6 Base Replacement, Remove palmrest cables & screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the lock of the power button cable, and pull the cable out.
    • Repeat the process for the touchpad cable...
    • ...as well as the speaker cable.
    • Remove the three M2.5x4 screws securing the palmrest.
  4. HP Pavilion g6 Base Replacement, Undo cables: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Undo the lock for the USB port connector, and pull the cable out. Also pull on the power jack connector right beside it.
    • Pull up on the optical drive connector.
    • At this point, the motherboard should simply lift upwards.
  5. HP Pavilion g6 Base Replacement, Remove LCD assembly, DC Jack & USB Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the clip for the USB board to the left, and pull up on the USB board.
    • Pull up on the DC jack.
    • Remove the two M2.5xL6.5 screws securing the right hinge to the base. Do the same for the left side.
  6. HP Pavilion g6 Base Replacement, Remove optical drive connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the clip for the optical drive connector, and then pull the connector out.
crwdns2935229:09crwdne2935229:0
Joseph Sctbunio
crwdns2935283:009/23/17crwdne2935283:0
7,578 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
crwdns2942667:0crwdne2942667:0 10,283
