Although it does not have many prerequisites, the screen is without a doubt the most difficult part of the laptop to remove. There are several hidden screws and wire that need to be carefully removed.
Slide pill shaped tab to the other side of the channel.
Remove battery while keeping the tab to the side.
Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
Remove four 4.0mm JIS #0 screws located at each corner of the monitor.
Remove four 3.0mm JIS #0 screws, two on each side of the screen.
nice very informative
