HP Pavilion dv9000 Hard Drive Replacement
  1. HP Pavilion dv9000 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two hard drive bays.
    • Hard drive bay 1 is in the lower right corner.
    • Hard drive bay 2 is in the lower left corner.
  4. HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove hard drive 1 from bay 1
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
    • The screws should remain in the cover.
  5. HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the two cover screws, lift and slide the cover out of position to access the hard drive.
    • Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
  6. HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove hard drive 2 from bay 2.
    • Most laptops don't have a second hard drive. If yours does not, then proceed to the next step.
    • Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
    • Grab the clear plastic pull tab on top of the hard drive, and lift the hard drive from the laptop.
  7. HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv9000 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the hard drive has been removed from the laptop, it must then be removed from its bracket.
    • Start by gently pulling the HP hard drive adapter from the end of the hard drive.
    • Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
    • Lift the hard drive from its metal bracket.
    • Be careful not to touch the green underside as this may damage the hard drive.
crwdns2935229:08crwdne2935229:0
Robby Cabri
crwdns2935283:001/23/14crwdne2935283:0
178 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-32, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 10-32, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S10G32
Hello. In step 7 of the above, what is the name/part number/ size etc of the adapter/connector please ? I need one urgently.
Thanks.
freeflyshannon - crwdns2934203:0crwdne2934203:0
yes that would be very helpfull because the new SSdrive I have will not fit even though is is the same size. I think I need some sort of an adaptor as you say.
Stephen Cox - crwdns2934203:0crwdne2934203:0
For modern SATA SSDs, the typical form factor is 7.5mm. The standard for laptop HDDs is 9.5mm. You will need to buy a plastic spacer in order to properly mount the drive inside your computer.
Michael - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,216
