HP Pavilion dv7-3065dx Keyboard Replacement
  1. HP Pavilion dv7-3065dx Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-3065dx Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Keyboard Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
  6. HP Pavilion dv7-3065dx Keyboard Replacement, Keyboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate these seven screws that fasten the keyboard and switch cover to the computer.
    • Remove these screws
  7. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the computer to the upright position and locate the switch cover.
    • Carefully pry the switch cover up until it detaches from the computer.
    • The switch cover is held in with plastic clips. They may break if they are removed too forcefully.
  8. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise the switch cover to expose the speaker assembly.
    • Carefully detach the ribbon cables from the speaker assembly.
    • Locate and remove these four screws from the switch cover.
  9. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the screws that hold the keyboard to the computer.
    • Lift the keyboard up to expose the keyboard connector.
    • The keyboard connector is the small cord located near the screen of the computer.
  10. HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-3065dx Keyboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the keyboard connector by unhinging the blue plastic clips and gently pulling the cord.
    • The keyboard can now be removed from the computer.
Nicholas Moore
crwdns2935283:002/07/17crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-5, Wilder Spring 2017 crwdns2935289:0Ohio State, Team 1-5, Wilder Spring 2017crwdne2935289:0
OSU-WILDER-S17S1G5
crwdns2942667:0crwdne2942667:0 1,945
