Ensure the device is powered down and unplugged.
Turn the device upside down with the battery compartment facing you.
Slide the black slider to the right and lift the battery out of its compartment.
Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
Use the plastic opening tool to lift up the back plate and set it aside.
Locate the wifi card to the right of the RAM.
Unplug antenna cables 1 and 2 from their leads.
Remove the two Phillips head screws located on the battery compartment side of the wifi card.
Gently lift the wifi card up to a 45 degree angle from the side with screws.
Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
Gently push the wifi card down until the screws can be replaced.
