HP Pavilion dv7-1285dx Keyboard Replacement
  1. HP Pavilion dv7-1285dx Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement, Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips Screwdriver, remove the four Phillips M25x3.0 head screws.
  3. HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool on both the left and right sides to remove the upper portion of the top plate.
    • Orient the device such that it’s partially opened (a little less than a 45 degree angle) and the hinge faces up.
  4. HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the laptop so the screen is open and facing you.
    • Grasp the top plate near the hinge and pull up.
    • This should expose a white ribbon cable.
  5. HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the dark grey slide on the sides of the ribbon cable plug.
    • Using the plastic opening tool, push both sides of the dark gray slide towards the screen of the computer.
    • Unplug the ribbon cable and set the top plate aside.
  6. HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the four Phillips M2.0x2 head screws at the top of the keyboard and remove them.
    • Gently lift the keyboard up from the screen side and pull the keyboard towards the screen.
  7. HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv7-1285dx Keyboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the black ribbon cable attaching the keyboard to the computer.
    • Find the grey slides on the side of the ribbon cable plug.
    • Use the plastic opening tool to move the grey slides toward the screen.
    • Unplug the black ribbon cable.
    • Remove the keyboard.
Jesse Quisido
crwdns2935283:004/14/14crwdne2935283:0
489 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-34, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 12-34, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S12G34
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 3,896
