This guide would be used if your screen gets damaged or no longer functions. All screws are a PH00 size. It would be advisable to keep track of which screws go where, as there are a lot of screws that will be removed over the course of this guide. Be sure to wear the anti-static guard strap, as that will protect the circuitry from permanent damage from static electricity.
Flip over the device so that the bottom is facing you.
Locate the battery on the bottom of your laptop.
Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
Remove the RAM port cover by unscrewing the two screws.
Use a Phillips #00 screwdriver to remove the two screws securing Hard Disk Drive (HDD) cover.
Use a Phillips #00 screwdriver to remove the 25 screws securing the bottom of the computer.
Using the Phillips #0 screwdriver remove the 2 screws.
Flip over HP Pavilion dv6700 so that the top is facing you.
Open up HP Pavilion dv6700.
Use an iFixit opening tool to pry open the plastic bar above the keyboard.
Pull out and up on keyboard to remove it.
Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
Grip the ribbon cable near the connection point and gently but firmly pull it out.
Flip over the plastic bar.
Detach the display connector.
Pull up on the WiFi wires and out from under the metal tabs.
Disconnect the connector from the port.
Remove the wire from under the metal tabs.
Let wire hang loose after removing under the tabs.
Use a Phillips #00 screwdriver to remove the black screw located in the top right corner near the display.
Pull upward on the screen connector tab.
Use a Phillips #00 screwdriver to remove the black screw securing the screen.
Lift the screen off and set it aside.
