HP Pavilion dv6-6117dx WiFi Adapter Replacement
  1. HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement, WiFi Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, remove the white and black antenna wires from the WiFi Adapter
    • When connecting these wires later, line up the connector and press straight down until you feel them snap in place.
  5. HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screw driver, remove the two 4mm screws holding the WiFi adapter in place
    • After the screws are removed the WiFi Adapter will raise to a 45º angle.
  6. HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv6-6117dx WiFi Adapter Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Always handle the WiFi Adapter by the edges to avoid damaging the part.
    • Pull the WiFi Adapter out of the slot at a 45º angle.
    • When inserting the new WiFi Adapter, you should insert it at this same angle.
Joshua Holme
crwdns2935283:003/19/18crwdne2935283:0
765 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 crwdns2935289:0UMass Dartmouth, Team S6-G3, Bernier Spring 2018crwdne2935289:0
UMASSD-BERNIER-S18S6G3
Thanks i need to replace the wifi adapter in an old pc of mine,looks pretty simple.
pturner14 - crwdns2934203:0crwdne2934203:0
I have hp dv6 notebook pc ww140AAR unable to load any OS. While installing the os a Blue Screen popup "ur pc runs into a problem need to shutdown" and then shutdown. And heating too much. Local engeneer said u have the replace the motherboard.what should I do now. Plz. Guide me.
Tanveer alam - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,631
