HP Pavilion dv6-2158nr RAM Replacement
  1. HP Pavilion dv6-2158nr RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-2158nr RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-2158nr RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. HP Pavilion dv6-2158nr RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-2158nr RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-2158nr RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  4. HP Pavilion dv6-2158nr RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-2158nr RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv6-2158nr RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
Chad
crwdns2935283:001/13/14crwdne2935283:0
1.123 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-34, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 10-34, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S10G34
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,592
