HP Pavilion dv4-4141us Fan Replacement
  1. HP Pavilion dv4-4141us Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the back panel using a spudger, and remove it from the device.
  2. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #1 screwdriver unscrew the panel from the computer.
    • Lift the panel up and remove it from the laptop.
  3. HP Pavilion dv4-4141us Fan Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to lift the left side of the hard drive.
    • Unplug the hard drive and remove it from the device.
  4. HP Pavilion dv4-4141us Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement, Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 Screwdriver to remove all the screws indicated in the pictures.
  5. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use opening tool to separate the Key board and mouse pad.
    • It would be best to find a tool that is small enough to fit and start on the bottom at either corner and slide across lifting the panel up.
    • Be careful not to push too far underneath to not damage the interior and also it is advised to not bend or crack the plastic back cover.
  6. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to gently lift the white plastic flap and release the ribbon cable holding the keyboard in place.
  7. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to lift up the flap and release the cable for both of these two separate components.
    • Be extra careful not to break these clips as they are fragile and are a part of the motherboard.
  8. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the last wire holding the motherboard in place. To do this pull down on the wire in the direction of the arrow.
  9. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take out the mother board and flip it over so that you can access the fan.
    • Unscrew the two screws holding the fan in place.
  10. HP Pavilion dv4-4141us Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the fan from the motherboard by disconnecting the wire from the fan.
Vincent Gardner
crwdns2935283:010/25/21crwdne2935283:0
390 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-3, Sinclaire Fall 2021 crwdns2935289:0UMass Dartmouth, Team 2-3, Sinclaire Fall 2021crwdne2935289:0
UMASSD-SINCLAIRE-F21S2G3
Thanks! I was able to upgrade my Intel Core i3 2330m to a considerably more powerful core i5 2410m! The instructions were very easy to follow. This fixed my problem!
Sam Watson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 494
