For safety reasons it is important to make sure your power adapter is disconnected and your battery is removed. After doing these two things, you can begin tampering with other parts of your computer.
Turn your laptop over so the bottom of your laptop is facing up and the hinge is located away from you
Lift up the released battery by rotating it up and away from you.
Pull the battery out.
