HP Pavilion dv2000 Hard Drive Replacement
    1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Phillips #00 Screwdriver
      $5.49
      • Flip your computer over, so that the underside of your computer is facing upward.
      • Make sure your computer is powered down and unplugged from the charger before removing any components.
      • Locate the hard drive casing on the bottom-right corner of your flipped computer.
      • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
      • Screws on hard drive casing will remain in casing after being unscrewed.
    2. HP Pavilion dv2000 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion dv2000 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion dv2000 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Phillips #000 Screwdriver
      $5.49
      • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
      • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
Erik Muniz
crwdns2935283:009/09/14crwdne2935283:0
847 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-3, Bruce Fall 2014 crwdns2935289:0CSU Fullerton, Team 2-3, Bruce Fall 2014crwdne2935289:0
CSUF-BRUCE-F14S2G3
crwdns2935297:036crwdne2935297:0
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 5,085
