HP Pavilion Wave 600-a014 System Fan Replacement
  1. HP Pavilion Wave 600-a014 System Fan Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
  7. HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing your hard drive, remove the two 1.2mm Phillips #1 screws from the bottom of your case .
  8. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 mm Phillips #0 screw that is connected the top bezel and the top cover using the driver kit.
  9. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a flathead screwdriver, remove the 8 mm Phillips #1 screw that connects the body casing and the top bezel(the one at the bottom of memory card slot).
  10. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top bezel.
    • You will have to take off a pair of wire connecting the bezel with the body to be able to completely detach it.
  11. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device to the top side where you can see the top cover and the speaker.
    • Using a flathead or Phillips #1 screwdriver, unscrew all the eight 8.0 mm screws that connect the top cover to the other components of the casing.
    • Gently remove the top cover.
  12. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the top cover, locate the system fan on the left side of memory compartment.
    • Remove three 1.2 cm Phillips #1 screws that connect the fan with the main body.
  13. HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Wave 600-a014 System Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Simply slide up the fan after removing the screws.
Kyaw Soe
crwdns2935283:009/27/17crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S8-G4, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S8-G4, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S8G4
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,342
