HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
    12- M2x4 screws to remove. And it helps to remove the screws holding the elbow because it releases the front plate at the top corners.
    Con Fran - crwdns2934203:0crwdne2934203:0
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
Robert Hemphill
crwdns2935283:001/22/15crwdne2935283:0
278 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-22, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 21-22, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S21G22
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
crwdns2942667:0crwdne2942667:0 1,741
