If your keyboard is missing keys, sticky, or the keyboard is not responding you may need to replace your keyboard. This guide will cover how to remove the keyboard for replacement.
Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
Pull off the plastic cover of the laptop.
Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
Use a spudger to lift the keyboard plate off of the base of the computer.
Remove the screws connecting the keyboard to the underside of the plate
Detach the ribbon wire connecting the keyboard to the hardware.
Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
