HP Pavilion TPN-C125 RAM Replacement
  1. HP Pavilion TPN-C125 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over so the bottom is facing up and the external battery is at the top.
  2. HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumbs to slide the battery locks towards the center and pop the battery out.
  3. HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly peel off the two rubber stoppers found at the top corners of the laptop.
    • This will expose two Philips #00 10 mm screws required to remove the back plate.
    • Be careful not to peel off the rubber stoppers too quickly as it could cause the adhesive on the rubber stopper to strip off.
  4. HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the twelve 10 mm screws (from the twelve holes shown) that secure the bottom case.
    • Use an opening tool to carefully separate the back case from the chassis, working around all four sides.
    • You will hear a "click" as you release the clips and remove it.
  5. HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The RAM sticks can be found in the bottom right section of the laptop.
    • Push both side arms holding the RAM stick in place outwards.
    • The RAM sticks will "pop" up at a 45-degree angle when released from the arms.
    • Slide the RAM sticks out of the socket gently.
  6. HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion TPN-C125 RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully slide the new replacement RAM sticks into their slots.
    • Make sure to align edge of the RAM sticks with the slots to avoid damaging both.
    • Gently push the RAM sticks downward until the latches click into place to secure them.
Cesar Gomez
crwdns2935283:003/05/24crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 7-10, Grodsky Spring 2024 crwdns2935289:0CSU Los Angeles, Team 7-10, Grodsky Spring 2024crwdne2935289:0
CSULA-GRODSKY-S24S7G10
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 216
crwdns2942667:0crwdne2942667:0 2,761
