HP Pavilion Sleekbook 15-b000 Motherboard Replacement
  1. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Hard Drive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
  14. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove hard drive from bracket being careful of it's cable.
  15. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect cable from hard drive.
  16. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect motherboard cable from left side USB and jacks
  17. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  18. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove motherboard.
Sam Barkley
crwdns2935283:002/13/18crwdne2935283:0
1,007 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G2, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G2, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G2
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 742
