HP Pavilion Sleekbook 15- b000 Fan
  1. HP Pavilion Sleekbook 15- b000 Fan, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull battery out.
  5. HP Pavilion Sleekbook 15- b000 Fan, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15- b000 Fan, Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15- b000 Fan, Fan: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three x 5.5 mm restraining screws.
  14. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull fan of of heat pipe.
  15. HP Pavilion Sleekbook 15- b000 Fan: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove fan.
Sam Barkley
crwdns2935283:002/13/18crwdne2935283:0
1,007 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S11-G2, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G2, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G2
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 490
