If the screen of your laptop is black when powered on, or cracked, it should be replaced. With the purchase of a new screen, follow these steps to replace it completely.
Open your laptop. Beneath the screen, there is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
To remove this, pry it open with a spudger tool gently. It should pop out of place.
Gently use a spudger tool or your fingers to disconnect the LCD cable from the screen.
Remove the 1 cm screw with a Phillips #1 screwdriver to allow the screen and top of the laptop to be separated from the keyboard and bottom.
Lift the entire top away from the bottom, and set bottom half of the laptop aside.
Remove the 6 rubber screw caps with a metal spudger.
After removing the 6 rubber screw caps, use a Phillips #1 screwdriver to unscrew the six 6mm screws.
To separate the plastic cover, use a plastic opening tool to undo each plastic connecting clip between the two.
Remove the top plastic cover once all connections have been released.
Disconnect the connectors using a plastic opening tool.
At each corner, there is a 1 centimeter silver screw connecting the screen frame to the laptop. Remove these using a Phillips #1 Screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
There should be thin piece of copper 'tape' holding the LCD cable down. Remove this gently with tweezers.
Remove the screen from the device.
