HP Pavilion N3350 Optical Drive Replacement
    1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
      • To remove this, pry it open with a spudger tool gently. It should pop out of place.
    2. HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the three 6mm screws using a Phillips #1 screwdriver.
      • Once the screws are removed, the keyboard is free from the base of the laptop.
    3. HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the green ribbon cable using a plastic opening tool.
    1. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
      • Remove the top plastic covering from the base of the device.
    2. HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to disconnect both cable connectors gently.
    3. HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once these cables are disconnected, the optical drives can be found inside.
      • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
    4. HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
      • Once freed, the CD/DVD combo drive should slide out and remove easily.
    5. HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion N3350 Optical Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
      • Remove the floppy disc drive from the device.
Lyndon Davis
crwdns2935283:003/19/18crwdne2935283:0
124 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G8, Peak Spring 2018 crwdns2935289:0UMass Dartmouth, Team S3-G8, Peak Spring 2018crwdne2935289:0
UMASSD-PEAK-S18S3G8
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 592
