If the keyboard on your laptop is malfunctioning, has numerous missing keys, or is broken, it will need to be replaced. Once a replacement is purchased, follow this guide to effectively replace it.
Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
To remove this, pry it open with a spudger tool gently. It should pop out of place.
Remove the three 6mm screws using a Phillips #1 screwdriver.
Once the screws are removed, the keyboard is free from the base of the laptop.
Disconnect the green ribbon cable using a plastic opening tool.
