HP Pavilion G7-2289wm Fan and Heat Sink Replacement
  1. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Optical Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
  4. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the edge of the service cover toward you to remove it.
  5. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the hard drive connector cable from the motherboard.
  6. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
  7. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  8. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
  9. HP Pavilion G7-2289wm Fan and Heat Sink Replacement, Fan and Heat Sink: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws that hold the keyboard palm rest in place using a Phillips #0 screwdriver.
    • Lift the palm rest up and out.
  10. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wires attached under the keyboard.
  11. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open the bottom of the laptop by using the opening tool to open it up. Do this around the entire outer edge of the laptop.
  12. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw that holds the motherboard in place.
    • Remove the wires attached to the motherboard.
    • Unplug the laptop fan.
  13. HP Pavilion G7-2289wm Fan and Heat Sink Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws that hold the fan and heat sink in place.
    • Remove the entire heat sink from the laptop.
Clayton LaBrecque
crwdns2935283:003/19/18crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 crwdns2935289:0UMass Dartmouth, Team S8-G1, Valliere Spring 2018crwdne2935289:0
UMASSD-VALLIERE-S18S8G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 532
