For the RAM replacement of your laptop, you will need a screwdriver and a couple other tools. This is a relatively easy replacement and should take no more than five minutes.
Slide the battery release switch to the center of the computer to release the battery.
Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
Slide the cover towards you, then pull up to remove it.
Locate the RAM card and the two prongs holding it in place.
Using either your fingers or two metal tools, push outwards on the two prongs until the RAM card pops out.
The RAM card can now be pulled out at a slight angle.
