HP Pavilion G60-247CL Fan Replacement
  1. HP Pavilion G60-247CL Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Fan Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate RAM access door on the bottom side of the laptop.
  3. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  4. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  5. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  6. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the RAM stick up and out of its seat.
  7. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the previous two steps for the remaining stick of RAM.
  8. HP Pavilion G60-247CL Fan Replacement, Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  9. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven Phillips #0 screws from the battery compartment.
  10. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the computer around to the front side.
    • Using an opening tool, prop open the keyboard casing.
  11. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  12. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  13. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  14. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black wire from the top right corner by gently pulling outward.
  15. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  16. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  17. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  18. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  19. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  20. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  21. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  22. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  23. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Prop the screen up slightly.
    • Using the tweezers unclip the white wire.
  24. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While the screen is still propped open, remove the black wire from the bottom middle of the screen by pulling gently.
  25. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen from the outer casing carefully.
  26. HP Pavilion G60-247CL Fan Replacement, Speakers: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement, Speakers: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery and RAM.
    • Locate the hard drive access panel.
    • Remove the two 1.2mm Phillips #1 screws on the hard drive access panel.
  27. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the screws are removed, slide the hard drive panel to the right to remove it.
  28. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the 3 screws holding the hard drive's cover in place.
    • Use a Phillips #0 screwdriver to remove the 3 screws and reveal the hard drive.
    • This particular laptop does not contain a hard drive-- yours will.
  29. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the storage battery, next to the hard drive.
    • Gently pop out the storage battery with your fingers.
  30. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the Wi-Fi card cover panel, to the left of the RAM.
    • Use a Phillips #1 screwdriver to remove the screw from the Wi-Fi card cover panel.
  31. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the screw side to remove the panel.
  32. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 1.2 mm Phillips #01 screws.
    • When the screws are removed, the Wi-Fi card will pop up.
  33. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Wi-Fi card by pulling it to the left of the laptop.
  34. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over to the top view.
    • Remove five 1.2 mm Phillips #00 screws.
  35. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to unclip the casing around all the corners and edges of the laptop.
  36. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up and remove the casing to reveal the speakers.
  37. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the highlighted 1.2 mm Phillips #00 screw from the right speaker.
  38. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, remove the highlighted white wire.
  39. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, remove both highlighted wires from the motherboard.
  40. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift each speaker up and out from the base.
  41. HP Pavilion G60-247CL Fan Replacement, Fan: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement, Fan: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the fan in the top left corner.
    • Carefully disconnect the wire attached to the motherboard using your fingers.
  42. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the disk player in the bottom right corner.
    • Remove three screws using a Phillips #00 screwdriver.
  43. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide out the disk player to the right.
  44. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently disconnect the ribbon cable using an opening tool.
  45. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wire connected to motherboard by gently pulling downwards.
  46. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wire connected to the motherboard using an opening tool.
  47. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove motherboard with fan from the shell.
  48. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip over the motherboard to view the back side.
    • Remove four 1.6 mm screws with a Phillips #1 screwdriver.
  49. HP Pavilion G60-247CL Fan Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G60-247CL Fan Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift out the fan.
Haley Matthews
crwdns2935283:003/12/18crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G5, Covino Spring 2018 crwdns2935289:0UMass Dartmouth, Team S4-G5, Covino Spring 2018crwdne2935289:0
UMASSD-COVINO-S18S4G5
crwdns2942667:0crwdne2942667:0 406
