HP Pavilion G6 Screen Replacement
  1. HP Pavilion G6  Screen Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Remove the battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Close the laptop and flip it over.
    • Slide the release pin to pop the battery.
    • Remove the battery completely.
  2. HP Pavilion G6  Screen Replacement, Remove the screw covers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Remove the screw covers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Remove the screw covers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop and locate the screw covers.
    • Remove the screw covers at the bottom of the screen with tweezers.
    • Keep them somewhere safe as you will need to stick them back after the repair.
  3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Remove the plastic frame: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Remove the plastic frame: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the exposed 2 x Philips screws and set them aside.
    • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
    • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
    • Finally, remove the frame.
  4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Release the screen from the frame: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Release the screen from the frame: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black Philips screw from the top on each side.
    • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
    • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
  5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
    • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
    • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
  6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion G6  Screen Replacement, Check the model number before ordering: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
    • Check the cable connector to make sure you order the correct screen with the correct number of pins.
honakrisi
crwdns2935283:001/28/20crwdne2935283:0
3 730 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,532
