HP Pavilion DV3 RAM Replacement
crwdns2869540:0crwdne2869540:0: 2.6천
4
19
87
2,614
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 4
crwdns2959982:04crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This guide instructs you how to remove the RAM. You will need the screwdriver listed in the tools section.
    1. HP Pavilion DV3 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
      • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
    2. HP Pavilion DV3 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV3 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
    1. HP Pavilion DV3 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion DV3 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion DV3 RAM Replacement, RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
      • Both screws will remain attached to the cover.
      • Set the cover with attached screws to the side.
      • The RAM will now be exposed
    2. HP Pavilion DV3 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion DV3 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion DV3 RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Find the two clips located on each side of the RAM.
      • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
      • The RAM will pop up.
    3. HP Pavilion DV3 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV3 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using one hand, pull the RAM up and to the left to remove it.
    4. HP Pavilion DV3 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
Brandon Baldovin
crwdns2935283:009/30/13crwdne2935283:0
548 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-10, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-10, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G10
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 87
crwdns2959996:0crwdne2959996:0 2,614
