HP Pavilion DV3 Hard Drive Replacement
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion DV3 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
crwdns2935229:05crwdne2935229:0
Luke Whitmarsh
crwdns2935283:009/30/13crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-10, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 14-10, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S14G10
crwdns2942667:0crwdne2942667:0 5,153
