HP Pavilion DV2160BR Inverter Replacement
  1. HP Pavilion DV2160BR Inverter Replacement, Inverter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with the laptop sitting up and open.
  2. HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
    • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
    • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
    • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
  3. HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
  4. HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The inverter is located underneath the screen.
    • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
  5. HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
    • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
  6. HP Pavilion DV2160BR Inverter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the inverter from the device.
Shannon
crwdns2935283:004/11/13crwdne2935283:0
55 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-66, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-66, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G66
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,505
