HP Pavilion DV2160BR Hard Drive Replacement
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion DV2160BR Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Shannon
crwdns2935283:004/11/13crwdne2935283:0
55 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-66, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-66, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G66
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 598
