In this guide you will learn how to remove the DVD±RW Drive from an HP Pavilion DV2160BR.
Start with the bottom of the laptop facing up.
Locate the battery compartment at the rear of the device.
There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
Locate the locking screw which is located in a recessed hole on the underside of the laptop.
Remove the M2.5X3-Lg #1 Phillips screw.
Locate the CD drive tray release hole on the front of the drive.
Straighten a paper clip and push it gently into the CD drive tray release hole.
The drive tray will pop open.
Grasp the side edges of the drive tray.
Gently pull the drive from the laptop.
Locate the mounting bracket which is attached to the back of the drive.
Remove the two M2x3-Lg #0 Phillips screws.
