Hard drives are prone to failure, causing computer files to become inaccessible. This guide will explain how to replace a defective hard drive in the HP Pavilion DM3-3010US.
            Flip laptop over to back with the battery facing downwards.
            Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
            Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
            Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
            Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
