This Guide covers how to replace the 17.3 in display on the Hp Pavilion. Only replace if it is beyond repair and required.
Slide the battery lock to the right until you see the open lock symbol.
Slide the battery release to the left until the battery pops up.
Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
Remove the two 7mm screws with a Philips #00 screwdriver.
Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
Unplug the wire connected to the display assembly by gently pulling on it.
Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
