HP Pavilion 17-g192dx Motherboard Replacement
  1. HP Pavilion 17-g192dx Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Motherboard Replacement, laptop: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the metal spudger, pry up the screw covers.
  5. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
  6. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
  7. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an iFixit opening tool, push the disc drive away from the outer case.
    • Once the disk drive is out far enough, it easily slides out.
  8. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
    • Using a metal spudger, lift up on the back resting plate until it pops off.
  9. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7 mm screws behind the plate using a Phillips #00 screwdriver.
  10. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up on the case with an iFixit opening tool until you can feel a snap.
    • Pry around the remainder until you can separate the case from the keyboard with your hands.
    • Gently separate the two.
  11. HP Pavilion 17-g192dx Motherboard Replacement, RAM stick: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, RAM stick: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, RAM stick: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pry the two black tabs on either side of the RAM stick outwards until the RAM swings upwards to rest at an angle.
    • Gently slide the RAM out from the port maintaining the angle at which it rests.
    • The images show the RAM stick being pried from the port without being unlocked by the tabs. Be sure to use the black tabs to release it and avoid damaging the RAM or the motherboard.
    • During reinstallation, be sure to insert the RAM stick at a similar angle to which it rested after being unlocked. Then just press the stick down into place. There should be a click as the black tabs reengage to lock it in place.
  12. HP Pavilion 17-g192dx Motherboard Replacement, Cooling Fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, Cooling Fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, Cooling Fan: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2mm screws on the heat sink with a Phillips #00 screwdriver.
    • Remove the heat sink.
    • When setting the heat sink down, set it face down to avoid putting the thermal paste on the work surface.
    • When reinstalling the heat sink, be sure to clean the contact surfaces and reapply fresh thermal paste.
  13. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5mm screws holding the fan in place using the Phillips #00 screwdriver.
  14. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the cooling fan from the motherboard.
    • Remove the cooling fan.
  15. HP Pavilion 17-g192dx Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug all wires connected to the top of the motherboard.
    • Use an opening tool to lift up the tab located on top of the wires.
    • An opening tool will be needed for almost all of the wires.
  16. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4mm screws with a Phillips #00 screwdriver.
  17. HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Pavilion 17-g192dx Motherboard Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Double check everything is unplugged.
    • Lift up the motherboard and flip it over to the backside.
    • Remove the wire still attached to the back with a plastic opening tool.
    • Remove the motherboard.
Dominic Perito
crwdns2935283:009/20/19crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S2-G121, Watkins Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S2-G121, Watkins Fall 2019crwdne2935289:0
ERAU-WATKINS-F19S2G121
I really liked the this. Only 1 issue that I saw, lifting up the tabs some are black and some are white. That was not apparent to me to do because 1 close up shot of each would show you want to look for! Great Job overall!
Craig Minnesota USA
Craig - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 564
